Top mount starter jamming. >
Old 02-24-2019 | 10:18 AM
Craney's Avatar
It might be the way I’m looking at it but it looks like the starter is not engaging the fly wheel all the way.
Craney is offline
Old 02-24-2019 | 10:31 AM
why is there a washer in between the starter and bellhousing, looks like its sitting at an angle, starter should flush mount to the bell.
i also tried shimming it out with one then 2 washers same result as being flush.
chris302 is offline
Old 02-24-2019 | 12:53 PM
BUP
I see the same thing. I agree with you
Check run out on the flywheel
How strong is your BATTERY and that POWER ? Correct size battery here spinning over the engine ? 12.75 / 12.8 volts is fully charged and USE a cranking battery not a deep cycle battery. All marine manu strongly recommend a cranking battery NOT a deep cycle battery for engine starting and running the engine side. I would use a quality 1000 MCA cranking battery.
And not a walmart nor a O reilly nor a costco batteries period and IMO blue top OPTI s are junk to.
BUP is offline
Old 02-24-2019 | 02:27 PM
F-2 Speedy's Avatar
Ive seen this before when the engine isn't started, pull the plugs and crank the engine a couple rotations and see if it disengages ? if not rotate the crank clock wise with a break over bar just a bit and see if it disengages.
F-2 Speedy is online now
Old 02-24-2019 | 03:39 PM
Dumbass me was using jumper cables that were not up to it. Ran some heavy cable to the battery to starter problem solved.
thanks for all the responses!
Chris
chris302 is offline
Old 02-24-2019 | 03:54 PM
Chris
looks like BUP got the fix right.nice job
sutphen 30 is offline
Old 02-24-2019 | 06:24 PM
BUP
[QUOTE=BUP;4674141]I see the same thing. I agree with you
Hopefully some of that info helped and a Volt meter - and Voltage DROP testing when you hit the starter. Had a feeling it was something to do with POWER / Voltage not spinning over the engine hard enough. Just saying.
BUP is offline
Old 02-24-2019 | 07:14 PM
[QUOTE=BUP;4674191]
sure did and thanks!!
chris302 is offline
