A wire diagram for a 35ft cigarette 1978 >
Old 02-24-2019 | 02:30 AM
Default A wire diagram for a 35ft cigarette 1978
im needing a schematic for a 1978 cigarette mistress, I have no lights on boat that work , any info
Cigarettemistress1978 is offline
Old 02-24-2019 | 07:33 AM
Standard wiring diagram
AllDodge is offline
Old 02-24-2019 | 10:44 AM
First step is a volt meter and start checking power and fuses
ICDEDPPL is offline
Old 02-24-2019 | 11:24 AM
seafordguy's Avatar
I have the original from my Cafe Racer scanned. If you send me an email I'll forward it to you.
Eric.ancarrow (at) Ferguson.com
seafordguy is offline
Old 02-24-2019 | 01:49 PM
Ok thank you
Old 02-26-2019 | 04:42 AM
Full Force's Avatar
Like Dan said, meter and time.... the colors for the wiring are mostly standard and I doubt you will find the scheme for that mistress, I could not find one with my 85, start at the switch and see if you have power, if not go backwards to panel as nothing is labled, if you have power to switch check wiring out, and grounds... odd to lose them all so I will say most likely power to switch.
Full Force is offline
Old 02-26-2019 | 10:29 AM
BUP
Prob rodent eat the wires - man this is so common in my area. The rodents actually think the wire insulation is food because the insulation can be made and or has a soy base product in it.
Every darn spring someones boat has chewed up wires for whatever.
BUP is offline
Old 02-26-2019 | 06:45 PM
Not sure what problems he`s trying to solve when the boat hasn`t even been delivered.
ICDEDPPL is offline
