889275T Fuel Pump Assembly
Is this just a lift pump for an electric fuel pump? Or is it regulated to run a carburetor off of? I show's it will run off a sea pump from 525EFI-799SCI. Need a sea pump fuel pump.
https://www.mercruiserparts.com/889275t-pump-assy-fuel Thanks |
Would need to know what motor, but
You want 861677T https://www.mercruiserparts.com/861677t-pump-assy-fuel or Airtex 60932 which makes the pump for Merc |
Merc has these pumps done over in Korea if I recall correctly. Its fits the 525 hp and some other models as a boost pump to feed the high pressure electric fuel pump.
Originally Posted by AllDodge
(Post 4678553)
You want 861677T https://www.mercruiserparts.com/861677t-pump-assy-fuel or Airtex 60932 which makes the pump for Merc https://www.amazon.com/Airtex-60932-.../dp/B002HTYRD8 is the airtex a direct replacement for the merc. Bolt and go? |
I still have the 130gph Holley pump mated to the factory top for a sea pump if you’re interested. https://www.offshoreonly.com/forums/...ech-pumps.html |
Originally Posted by Crude Intentions
(Post 4678616)
(Post 4678553)
You want 861677T https://www.mercruiserparts.com/861677t-pump-assy-fuel or Airtex 60932 which makes the pump for Merc https://www.amazon.com/Airtex-60932-.../dp/B002HTYRD8 The engines are NA 502's Will this pump support 600HP NA? |
I’m running the stock merc pumps with 570hp carb engines to 6k rpm with no issues. |
Ive got a pair of sea pumps if you need them
Originally Posted by Rookie
(Post 4678681)
The Merc pump is an Airtex? The reviews on the Airtex are hit and miss. I believe mostly due to the rotation of the outlet. I believe it can be clocked differently by unbolting.
The engines are NA 502's Will this pump support 600HP NA? I'm running a Gen 2 cool fuel (530hp) without a mechanical pump in front and have no issue, and also the pump moves more fuel then my motor will use |
The Merc pump is said to flow at least 110gph while the Airtex equivalent is only listed to flow 40gph on Summits website. It supposedly has a different diaphragm, I don't know what else is different internally. Just a concern if you have any mods, 40gph is pretty low.
The Merc pump is said to flow at least 110gph |
Airtex shows 40gph at 1800 RPM free flow, not mention of higher RPM
https://cimg7.ibsrv.net/gimg/www.off...fb514e782a.jpg |
Currently running triple Holley black 140's.
(Post 4678856)
| All times are GMT -5. The time now is 01:04 PM. |
