600SCi Misfire.... >
600SCi Misfire....
600SCi Misfire....
Old 04-05-2019 | 06:29 AM
Dean Ferry's Avatar
Veteran: Air Force
Well, found number 2 coil is bad, the photo shows it next to a good one . Talked to BUP yesterday and he said it's called a secondary post failure
Dean Ferry is offline
Old 04-05-2019 | 07:06 AM
One of my 525s has developed a misfire over the winter. I fired it up last weekend, and idles fine, but won't rev properly. Getting to the coils is a b#tch on my boat, not looking forward to diagnosing this at all.
endeavour32 is offline
Old 04-05-2019 | 07:37 AM
Dean Ferry's Avatar
Veteran: Air Force
E32,
It's not easy that is for sure.....
Good luck with it, the easy way to find out which cylinder is misfiring is just fire up the suspect engine for about 1 minute, and just feel for the cold header runner....
Everything is for sale @ a certain $$
Old 04-06-2019 | 10:29 PM
I got lucky. Once the engine warmed up, it ran fine. I'm not sure how it was winterized, but after a few minutes on the hose, everything was fine. Then I took the boat to the lake, and everything was still fine. Feeling for the cool runner is a great tip.
Old 04-06-2019 | 11:56 PM
BUP
Prob was a tad of condensation in your fuel very common from lay up... All the fuel filters need to be changed at the spring commission and that fuel examined ? and fuel samples from the gas tank(s) are very recommended about 3 times per year min especially at layup and start of boating ?
BUP is offline
Old 04-14-2019 | 02:56 PM
Dean Ferry's Avatar
Veteran: Air Force
Coil replaced and misfire is gone, thanks BUP!
