Cigarette Cafe Racer prop choice >
Old 04-10-2019 | 08:51 AM
Default Cigarette Cafe Racer prop choice
Hoping for a little guidance here - thanks in advance.
1991 Cigarette Cafe Racer, Bravo 1, Currently spinning Bravo 1 4-blade 26P.
Rev limiter on new engines has been set at 5800 but I am barely seeing 5000. Depending on conditions / trim that will get me to low 70s. This is with fresh 550ci motors - dyno sheet below.
Wondering what direction to go in, if any.
ancho is offline
Old 04-10-2019 | 09:05 AM
F-2 Speedy's Avatar
Somethings seems off, at 640hp only spinning a 26p 5k..are the drives 1.5 ?
F-2 Speedy is offline
Old 04-10-2019 | 09:21 AM
As far as I know, yes they are 1.5
ancho is offline
Old 04-10-2019 | 10:50 AM
14 apache's Avatar
What exhaust did you have on dyno and in the boat?
14 apache is offline
Old 04-10-2019 | 10:53 AM
You may not have enough air flow into engine bay.
ph1971 is offline
Old 04-10-2019 | 10:54 AM
You may not have enough air flow into engine bay. I had this problem last year.
ph1971 is offline
Old 04-10-2019 | 11:02 AM
CMI headers. same on Dyno and in the boat. Dry tails because we were seeing water reversion at idle.
ancho is offline
Old 04-10-2019 | 11:03 AM
How did you remedy the problem? Scoops on top? Ducts on the side?
ancho is offline
Old 04-10-2019 | 11:07 AM
Also, I should mention, it seems like the last few clicks of throttle position towards WOT do nothing to increase RPM or speed.
ancho is offline
Old 04-10-2019 | 11:12 AM
I opened the decorative unoperable scoops on the side of my boat. I learned this was th problem by opening the hatch a crack and then test riding.
ph1971 is offline
