New Member looking for some help >
Old 04-17-2019 | 12:00 PM
Default New Member looking for some help
Hi My name is Jim and I have a 1989 Invader 17 ft jet boat. Boat originally came with a much smaller motor. When I bought it I had no idea the motor was changed. The boat now has a Mercruiser 454 and I'm trying to find out more about the motor and could use some help. The only # I could get off the block is 10114182 and the firing order is 18436572. I'm trying to find out what year and hp it is. When I cross reference the serial # I get nothing. So I'm not sure if this is the right number or if I'm missing something? I did get this number off the back of the block near the flywheel and above the starter. Ty Jim.
Invader454 is offline
Old 04-17-2019 | 12:14 PM
F-2 Speedy's Avatar
J Google is your friend .......454 Mark V 91-95 4 bolt main........
F-2 Speedy is offline
Old 04-17-2019 | 10:58 PM
That is the GM casting number and not a serial number. If it was a true Merc engine then it should be a 454mag which was rated at 365hp. There should be a Merc serial number tag near on the lower back starboard side of the engine.
Griff is offline
Old 04-17-2019 | 11:54 PM
BUP
engine serial dog tag above the starter.
BUP is offline
Old 04-18-2019 | 01:06 AM
BUP
BUP is offline
Old 04-18-2019 | 10:36 AM
I see the tag above the starter but can't make it out . Where else would the serial number be . I found that # just above the tag.
Old 04-18-2019 | 10:38 AM
Also the only thing I could make out on the tag is Mercury.
Old 04-18-2019 | 12:43 PM
That is the only place I know of. If it has an aluminum intake manifold and rect port heads, then it is a 454mag/365hp.
Griff is offline
Old 04-18-2019 | 02:27 PM
What years did they make that particular motor? I'm trying to figure out what year it is.
Old 04-18-2019 | 03:28 PM
F-2 Speedy's Avatar
See post #2 GM manufactured the block from 91 to 95
