I want to borrow a edelbrock proflow 90 mm throttle body for dyno testing
Nothing left in tune, all in. Took mufflers off today and w open headers made better tq below peak, same hp, around 680. Afrs in mid 12s to 13s at peak. Added a little more fuel by bumping up regulator from 41 to 45, pretty fast sweep rate (bonzai glory pull ) touched 698hp at 6300, was still climbing, fairly stock bott I m end though, already pushing it. I can say this after running this little baby half ass tunnel ram, THERE ARE TUNNEL RAMS IN MY FUTURE!
And back to throttle body:
This tb was mildly modded to get flow #s from low to.mid 900s out of box to low to mid 1100s.
digesting dyno data last night ,with open headers its quickly becoming "small", at 5000 rpms im seeing map readings in th 95s, thats 1.65" of vacuum, i can only imagine on a bigger motor what would happen.
Can I ask what you think you would have ended up with Trq/ Hpr with say a modded 502mpi intake with the TPIS throttle body same combo and also 500/525 EFI mercruiser intake wondering how much better you believe this is over those
Hi Smitty, I don't post much anymore but I like to check the Tech section to see what you're up to! Out of curiosity, how much difference does the playdoh make when you flow the throttle body?
530/.540. A typical modded merc mpi motor goes from .540/.550 to..580 or 600 pretty quick beyween 5600 and 5800 WITH tb amd intake mods
