What are these spots in my exhaust manifolds?
Found this pic from a previous post of yours.
If these is on your exhaust/boat I wouldn't worry about reversion. A million marine sbc people have run that cam with many different exhausts so we have a good handle on what will work or not.
If this is your t-stat housing I would worry about that for other reasons !
Thanks for the reply.
The engine is new and has not been put in gear yet as I have not put the drive back on the boat yet.
The times I have run it, I set the idle to about 750 as I recall.
At this point, I am not going to worry too much about it. I have a better exhaust than my cam requires and I don't see evidence of actual water in the manifolds.
I'll double check everything and then she's going to the lake as is. I'll pull the risers again once I get the boat out of the water.
Thanks again for the responses.
Russ
Russ
