Help on 1998 fountain 38 SC >
Old 05-24-2019 | 12:26 PM
Default Help on 1998 fountain 38 SC
I would accept any help on where the main power block is located. I lost the main power to the outdrive trim pump on the port side starboard side is fine. Thank you
Weekend therapy is offline
Old 05-24-2019 | 12:29 PM
F-2 Speedy's Avatar
Do you have all the batteries on ??
F-2 Speedy is offline
Old 05-24-2019 | 12:44 PM
Yes it was working fine put it up at the beach went to leave could not get it to go down.
Old 05-25-2019 | 12:43 AM
On my 1990 trim pumps, there's a fuse where the power wire connects. It doesn't look like a regular fuse. It's ~1 inch cube. Has to be replaced if blown.
zz28zz is offline
Old 05-25-2019 | 08:11 AM
Thank you I will check that today.
Old 05-25-2019 | 02:08 PM
I switched the little box with the other outdrive didn't make a difference the red wire that connects to that does not have any power the outdrive that works has power to it. I don't know where that red wire runs to trace it back. Does anybody know where that red wire runs to?
Old 05-25-2019 | 08:38 PM
Got it feel like a dame ***. Forget about the breakers under the bench seat.😆😆
