Engine heating >
Engine heating
Engine heating
Old 05-27-2019 | 04:39 PM
Default Engine heating
i was wondering if someone could help me out on this. I have a 300hp Diesel engine linked up to a bravo one drive. The engine temperature is fine until I go over 3200rpm then the temperature rises quickly. Any ideas what might be wrong? Would this be linked to my drive being too high and why I’m getting no trim up before I get blow out and no bow lift?
Yanmar315 is offline
Old 05-27-2019 | 05:31 PM
Tinkerer's Avatar
I assume that the exhaust comes out the prop. So you can't check the water flow out the exhaust.
when is the last time the seawater pump was serviced with a new impeller.
The other thing do it yourselfers forget is to clean the passages and check for blockages on the intake side of the oil cooler.
Pieces of the impeller tend to find their way into the oil cooler.
Tinkerer is offline
Old 05-28-2019 | 03:16 AM
No the water goes out the exhaust through the back of the boat and there is plenty going through it
Old 05-28-2019 | 09:14 AM
madbouyz's Avatar
Wouldn't that be a fwc engine ? Presuming that it is have you cleaned and acid dipped the heat exchanger recently ? It's very common for people to overlook the fact that they get grunged up and loose a lot of their heat transfer capability .
madbouyz is offline
Old 05-28-2019 | 08:06 PM
Tinkerer's Avatar
You say that you have a high prop height. How far below the hull is the prop shaft.
Is this a standard Bravo drive or one with low water pick up?
If it is a low water pick up hopefully it is not a dual water pick up.
Not a safe idea but set up a camera or have someone look over the back to make sure water is still coming out of the exhaust at above 3200 RPM
Tinkerer is offline
Old 05-29-2019 | 08:05 AM
It’s a bravo 1x drive and yep water flowing out the exhaust at all times but was thinking maybe if the drive was too high it might not be getting enough water after 3200 rpm. Would a drive spacer help this problem?
Old 05-29-2019 | 12:41 PM
madbouyz's Avatar
Maybe we should get back to ( a few ) basics.
A diesel with a B1 is a little on the unusual side. What make and model of boat is this ?
Is it new and you're the first owner and it's never done this before and has just suddenly started doing this or is it 2nd hand / used and you have discovered this problem as a new owner of the boat ?
madbouyz is offline
Old 05-30-2019 | 04:50 AM
It’s a 27ft Antibes columbo 8ft wide stern. It was a second hand boat but engine and drive was new but I’ve always had this bother from I first tested it. A few people have told me that the drive could be too high and that I should try a spacer kit to bring the bottom half on down.
Old 05-30-2019 | 01:05 PM
madbouyz's Avatar
Google search shows that to be a very sporty boat. Is it Italian made ?
Do you have any idea what the original drive system was ? If you believe that the current drive is too high is it a possibility that the old power plant had a unit that was deeper than the B1x and they utilized the original transom cutout ?
It's not difficult to confirm your suspicions that the drive is too high . Just haul the boat and eyeball the keel line in relation to where the water pickups on the drive are. If they are higher than the line of the keel then that could well be the problem .
Edit to add : If the water pickups are below the keel line then maybe it's a possibility that the raw water pump on the engine wants more water than the B1x pickups can provide and you might have to go with a separate transom mounted pickup . I wouldn't be quick to mess with the drive with spacers yet !
madbouyz is offline
Old 06-05-2019 | 03:07 PM
I have two of those engines in my boat, you can install a water pressure gauge in the big grey nut on the top of the intercooler where the sea water comes in, next to the zinc, should be 15 psi or so when running. That will tell you right away if it is a pressure issue. I have never had any cooling issues with mine but my seawater pickups are on the hull.
pstorti is offline
