Cracked 502 block
what is the difference between my mercury 502 block casting # 14096859 and a regular 502 block? I am looking at buying a brand new block, but all I can find is automotive blocks. Is there a real difference in block design and material. I have heard that my block is heavier than a normal auto 502. does anyone know where I can find another block like mine? New or used? Thank you in advance.
there is no normal automobile 502 as none came with them.
double check, but it looks like your's is a gen v 502 block. 14096859 Big Block V8 502, 4 bolt, Generation V |
Originally Posted by SB
(Post 4689789)
Originally Posted by payuppsucker
(Post 4689791)
I thought there were some 3500 series trucks that had 502s (8.2 liter) around 2008-2010. No?
Part is 14096859 Big Block V8 502, 4 bolt, Generation V |
(Post 4689791)
if there where, there would be lots more black stripes down your roads. :) lol. |
(Post 4689789)
double check, but it looks like your's is a gen v 502 block. 14096859 Big Block V8 502, 4 bolt, Generation V Thanks in advance, |
yes, rotating assy will work fine in a gen 6 block
Will my heads and intake work off my Gen V block? I would like to use my same heads. Thanks in in advance again |
Yes........^^^^ the gen VI uses a step nose cam design and a retainer ring that keeps it from walking around, dont think the gen V is like that.
| All times are GMT -5. The time now is 11:31 PM. |
