Oil out the exhaust >
Oil out the exhaust
Oil out the exhaust
Old 06-04-2019 | 10:40 AM
cigrocket's Avatar
Cooler Check First. Keep it simple and rule that out. Might be a really small crack that only shows up after hard runs and oil is thinnest. I wouldn't run it much till figured out. If it gives way, you will have no oil and be in trouble in a hurry. Just my 2 cents. At least you have a large Pan.
cigrocket is offline
Old 06-04-2019 | 10:41 AM
Would a bad oil cooler cause oil build up on the back of the boat though. Would it get hot enough to soot up, I dont see a sheen on the water while it idles
zeek987 is offline
Old 06-04-2019 | 10:54 AM
Yes. The oil entering exhaust stream through cooling water will turn the transom straight black. Wipe your hand up in the exhaust you’ll feel the oil. It’s the cooler.
Crude Intentions is offline
Old 06-04-2019 | 12:38 PM
Where is the pcv valve located. We had an issue where lifter tray was removed and pcv was sucking oil up into intake. Burned the equivalent oil you are...
1MOSES1 is offline
Old 06-04-2019 | 04:39 PM
BUP
496 does not have a PCV valve
BUP is offline
Old 06-04-2019 | 09:03 PM
reading the OP posts it seems not to be a Mercruiser 496, but a built from ? a stroked BBC so not a 496 as your thinking..........just saying
Camalot is offline
Old 06-04-2019 | 09:33 PM
BUP
YOU are 1000 % correct and I had no idea as from the start it was mentioned a 496. . I do not have the time to read all the posts but skim thru after the first post for most threads up here. . As boaters looking for help they should post all the important details and EXACTLY what they have so they can get the correct answers to help them out accurately from the get go. Thanks again for clearing up the exact engine
BUP is offline
Old 06-04-2019 | 09:39 PM
if i am reading this correctly this engine is a bored&stroked 454.that would be 4.310 bore with 4.250 stroke.if the oil cooler checks out and found to be good it could be a multitude of things,cracked block,blown head gasket cracked head,a lot of things to check.
mike tkach is offline
Old 06-04-2019 | 10:02 PM
BUP
Mike we all have to back up and ask was this boat properly winterized and by whom ? says compression good at 150 and NO power LOSS --- I take it then with those statements he can run full max RPMS and runs good as full power is felt thru out.
. I NEVER seen a marine engine with bad valve train components and or low compression and or very poor ring seal - blow by runs without having rpm issues and a true PIG thru out all rpms. - .
BUP is offline
Old 06-04-2019 | 11:06 PM
i agree,living in the midwest i get a few calls every spring from people with similar problems.cracked oil cooler was the first thing that came to mind but around here winter can cause all kinds of issues.
