Steel Tower for Bravo 1 >
Old 11-15-2002 | 10:15 PM
Maxx's Avatar
Dick, the information arrived today. Thanks alot! I have a customer's drive that needed "Blueprinting" this info will save me a tremendous amount of time setting up the correct back-lash for the upper gears.
Maxx is offline
Old 11-17-2002 | 10:37 AM
Mr Gadgets's Avatar
Charter Member #601
Maxx,
Your welcome!
Dick
Mr Gadgets is offline
Old 11-17-2002 | 10:50 AM
I have a 1990 Bravo drive that the tower (which appears to be part of the entire upper casting not a screw in part?) is ruined at the very top above where you can see splines when looking down from the top. Is this piece something that can be used to salvage the housing and make it usable again as well as increasing strength?
BGIII is offline
Old 11-17-2002 | 02:56 PM
Maxx's Avatar
BGIII, yes. The steel tower upgrade is fairly popular. The stock tower is milled off then I bore and thread the hole and install the steel one. The steel tower won't flex as much as the stock aluminum one will, and it can save the drive in the event of gear failure.
Maxx is offline
Old 11-17-2002 | 03:45 PM
Default Steel Tower
Maxx,where can it be done,I`v got a
clean upper 97 with broken alu tower,thanks.
Bjorn
502 Magnum is offline
Old 11-17-2002 | 04:07 PM
Thanks Maxx, looks like I need to have one of your steel towers installed and get my upper put back together so I'll have a spare.
BGIII is offline
Old 11-17-2002 | 05:15 PM
Maxx's Avatar
BGIII and 502 Mag, I do them here in Norfolk, VA. I sent y'all an email.
Maxx is offline
Old 11-17-2002 | 05:25 PM
Maxx's Avatar
BGIII, send me an email to: [email protected] Your profile won't let me email you.
Maxx is offline
Old 11-17-2002 | 06:49 PM
formula31's Avatar
Hi Maxx, Ive got a lower with way to much side play on the prop shaft. Ill get the nut and carrier out and bring it with me next trip. Ive never hurt a lower and as such, have never messed with them and dont have the tools to do the rear bearing if it needs it. See ya then. If its just the carrier bearing, I should be able to handle it.
formula31 is offline
Old 11-17-2002 | 08:03 PM
Maxx's Avatar
Sounds good Tom, if the carrier is damaged; I have an extra one.
Maxx is offline
