Compreesion Test
Guys, if you want to see the real interesting (goofy) way Mercruiser recommends doing a compression test look at Mercruiser Gasoline Engine Sevice Bulletin 97-25 (Merc. service bulletins are online). They recommend that the lowest cylinder can be within 70% of the highest cylinder. If the highest is 150 the lowest can be 105.
I am afraid that just wouldn't be good enough for most people!
Sincerely
Dennis Moore
FAMILY AND PERFORMANCE BOATING MAGAZINE
Sincerely
Dennis Moore
When my 502 scored a piston due to running lean the compression on that cylinder was 140 lbs. The rest were between 153 and 160. The leakdown test showed 50% leakage! You just can't beat a leakdown test when you want to be sure.
A compression test is much easier to do than a leakdown test so I always do that first. I would say that 5% or less difference between cylinders indicates a healthy motor. Anything more than that and I will do a leakdown test on the low cylinders.
Mac Tools has a dual guage (the best type) aircraft quality leakdown tester for $109.99. You can get them even cheaper than that if you look around.
checkmate454mag, Thanks for the info! I did a search on the web and found some instructions, and it looks very easy. If you rotate the crank with a wrench you can even check the condition of the whole cylinder. Very helpfull!
Dennis, I looked at that service bulletin and you are right, it isn't very good info.
Ok, I'm sold. I am going to buy one. One question.
some testers have 2 gauges, and I looks like it is just to monitor the input air pressure and not really needed if your have one on your air hose or compressor. Is this correct?
28Eliminator;
You are right. The testers with 2 guages use 1 guage to monitor and regulate line pressure, while the other measures leakdown percentage. If you have a guage on your compressor or the line, you really don't need the 2 guage tester. BUT, personaly, I like the 2 guage tester better.
Sincerely
Dennis Moore
Sincerely
Dennis Moore
thnx
