Mercruiser 500hp efi: Rocker Bolt cracked ... >
Old 06-15-2019 | 11:12 AM
Default Mercruiser 500hp efi: Rocker Bolt cracked ...
Hi I have an mercruiser 500hp efi engine... Ive just did a refurbishment to the engine... Now after testing the boat for a few miles... I found that the rockerarms nuts are cracking from the middle of the nut.. Any one had this problem before .. any ideas of whats causing the nuts to break ?
Thanks Sam.
Samsammlt is offline
Old 06-22-2019 | 07:05 PM
Roller rockers with polylock nuts I assume? Maybe over-torqued?
ctuck0659 is offline
Old 06-22-2019 | 07:13 PM
SB
Nuts not heat treated right or set screws over tightened, are the typical causes.
SB is offline
