-   -   Setting water dumps. (https://www.offshoreonly.com/forums/general-q/361311-setting-water-dumps.html)
Rhythm and Blues 06-18-2019 05:01 AM
Good morning, I’m questioning my test setup for water dumps. 3/4" Hardin Water psi reliefs. I turned in the dumps to full stiff, then I turned them out until I saw my target of 20psi on the gauge. Does that make sense? In my mind the slightly suspect element of this is the dumps are adjustable 7-25 psi but I'm basically in the middle of the range in terms of turns out from spring tension. https://cimg1.ibsrv.net/gimg/www.off...6a19d68fe4.png
Thanks in advance for the advise.
NHGuy 06-18-2019 04:17 PM
I wonder if it would change if the gauge we on the 90 and the feed was straight through?
Rhythm and Blues 06-18-2019 10:14 PM
hhmm, interesting. Maybe I’ll give it a go. Their still sitting there from last nights test.. Thanks. If for nothing else it’ll perhaps validate my findings. I would think it’ll the same.
