if you have an inline filter, try bypassing it. My system came with one on the pressure side and was a major restriction, magnet in the reservoir is sufficient.
thank you I will try that for sure , was told that something may need to be drilled to increase flow? anyone have any idea what this might be
Originally Posted by daniel475
(Post 4694949)
Modifying your Power Steering Pump - GM Truck Central |
I sent the same thing over to Daniel via PM. I had to do this on my Latham system.
(Post 4694924)
dual rams , single motor , yes it look a lot to initially prime it , the steering WAS working then my old merc power steering pump leaked so I thought I would replace it which I did , filled the new automotive one pretty much to the top obv could have been a little air in there , gonna try cracking rams at the back to see if there is any air ....
sounds good thanks for the advice gonna rip it apart AGAIN and drill the hole bigger , so ram hard over then crack the line at the back on the ram that's fully extended , im really losing patience really hope this fixes it
You'll love it when it's done. I did a poker run in my 311 last weekend... what a difference! The washing machine pretty much had no affect on the boat's direction, point and go! We also road back home about twenty-five miles across the Chesapeake Bay.... sitting at the helm barely even working the wheel... straight as an arrow!
You'll get it right Daniel. |
Is the steering running through a cooler before the fluid returns to the pump, where are you located, maybe someone on here could help out
located just outside of Vancouver British Columbia Canada , in Gibsons BC , I believe it is yes what are you thinking ill have to double check that , count down is on leaving next week for lake chelan poker run ! really hoping I get it figured
Well, BC is just a bit far from KS , personally I think there's air in the system, took me three tries to get my ITS jammin.....like TomZ said when its rite you're stylin like a Caddi
| All times are GMT -5. The time now is 04:46 AM. |
