Port side drive will not come up to trailer position? >
Old 07-05-2019, 12:31 PM
WHOSNEXT's Avatar
Default Port side drive will not come up to trailer position?
Both drives trim up and down fine, but when I'm ready to take the boat out of the water port side will not come up for trailer mode? what can I check?
WHOSNEXT is offline
Old 07-05-2019, 01:12 PM
Bravo drives I assume? Most likely the trim limit switch. Depending if this is a bravo or XR depends exactly where it is but it’ll near where the drive meets the helmet or on the pivots of the gimbal ring.
IGetWet is offline
Old 07-05-2019, 01:33 PM
WHOSNEXT's Avatar
Yes its a bravo One. I'm going to open the switch up and see if its making good contact.
WHOSNEXT is offline
Old 07-05-2019, 02:22 PM
GPM
May be a separate relay for trailer switch
GPM is offline
Old 07-05-2019, 02:56 PM
WHOSNEXT's Avatar
There is only one switch for both drives and the other drive works fine, unless the relay is on the pump?
WHOSNEXT is offline
Old 07-05-2019, 04:33 PM
Forum Regulator
Sydwayz's Avatar
Received 1,208 Likes on 524 Posts
FWIW, only a handful of builders use that capability. There is no issue with bypassing the trailer limit switch. .
Sydwayz is offline
Old 07-05-2019, 08:42 PM
WHOSNEXT's Avatar
how do I go about doing this?
WHOSNEXT is offline
Old 07-06-2019, 07:41 AM
Do you have HP transom assemblies?
JaayTeee is offline
Old 07-06-2019, 09:32 AM
WHOSNEXT's Avatar
Negative
WHOSNEXT is offline
Old 07-06-2019, 10:44 AM
maybe a wire came off of the trailer switch?
JaayTeee is offline
