Daytona Sensors idle stabilization ?
Does anyone have any hands on advice for using the idle stabilization feature ? Prior to looking into the specifics of its operation I assumed it could continuously vary timing as needed, but I now see you have to input a specific advance value which is what it will apply at a certain rpm. Is there rough correlation between degrees of advance and rpm or is it just trial and error unique to every engine? Just looking for a baseline starting point and what to expect or look for when making adjustments to the timing settings in the software. Also, as far as overall adjustment technique I guess the procedure would be to get the idle mixture on the money while in neutral and then instead of enriching the mixture to keep it idleing in gear you would use just the Daytona box to maintain idle. NA, 4500 application. Thanks for the help.
It's fairly straight forward, if you have a big cam na you may want to choose more degrees advance. On a 496 mark 4 with way too much cam initial was set at 14 degrees allowing up to another 14 degrees of advance for idle stabilization. Choose target rpm and I would suggest using the start retard function as well. With a little trial and error you will get it dialed in pretty quick. Its amazing what those boxes can do! Keep in mind that the application I just mentioned was a bad combo and those engines have much less cam in them now. Just proves what the daytona will let you get away with.
I am not an expert on it, but it does work well. The change in timing happens so fast that it is in fact variable timing. I would go ahead and set it at 20deg. On mine, I have the baseline timing set at 16 deg and the idle stabilization set to add up to 20 deg timing.
I agree with above. Give it the 20 and let it do its thing. When you set target low rpm it just keeps throwing timing to keep it above that rpm. Works great. |
Ok, the wording of the replys sort of indicates it will add as much as 20° if it is set at 20 (for example) constantly varying it below 20° as necessary which would be good. The instructions from Daytona don't provide much detail, I was worried if I had it set for 20° it would add all 20° at once as soon as rpm dropped below a certain point.
I just finished setting one up on my boat. You set the trigger timing value and create either a 2D or 3D timing table. I'm not running boost so I have a 2D timing table. I set the locked distributor to 36 degrees with all box functions off, then created a curve that started at 24 degrees at idle and ramped to 34 degrees at 3000rpm. This allows 12 degrees for idle control. If you lower the initial timing you will get more idle control timing advance. You can't exceed the the trigger timing set point. You can set a requested minimum rpm that it will try and maintain using the full 12 degrees. This is an on/off function, when you look at the data log the timing control is either full on or full off. The effect is less than I anticipated although better than without it. I still have a lot of tuning to do, but in neutral I run 900rpm and in gear 700rpm, with a set point of 850. I also use the timing retard on a 12VDC input. That allows me to run marina gas when I run out of 93 octane with the flip of a switch.
I`m not sure what you`re asking but stabilization is pretty simple. You set the rpm at which you want to add timing so the engine doesn't die.
I set mine at 750rpm to kick in and add 18* |
Originally Posted by ICDEDPPL
(Post 4697306)
^ as with most things ...it depends on what your combo wants
I do not have a daytona box...but I do have a timing box that allows me to use a 3D spark map. I got the engines warm, tied it to a dock, and put it in gear...then adjusted timing until it maintained my target RPM in gear with the most vacuum (mine ended up around 35*) while adjusting idle mixture/idle speed screw to compensate. My target RPM in gear is 800....in the 800 RPM column I have 15*......I then put a column in at 780 RPM with 35*. Now I have a warm neutral idle speed of about 900 RPM (still 15*...my "centrifugal" advance starts about 1100 RPM) and it drops to about 800 RPM when in gear. The idle mixture is set on the lean side of dwell in gear for all the no wake zones i have. The only time I have issues with the engines wanting to stall is the first about 30 seconds of run time for the day. These are solid roller 598's with dominators....somewhat mild (depending on your reference) cams, ~260* @ 0.050" on a 112* LSA. My goal was the leanest idle mixture without stalling while going into gear. I got it.....the change in RPM is hardly perceivable however, the change in tone while going into gear is drastic. It idles "smoother" in gear then out due to the bump in timing under load. |
The Daytona box throws what it needs. Give it the whole 20. Watch it with a timing light. It’s quite interesting to watch the timing bounce all over as it maintains the target rpm. It’s happening so fast it’s insane. |
| All times are GMT -5. The time now is 05:54 PM. |
