-   -   Lifter failed, wrecked cam, were they the correct parts? (https://www.offshoreonly.com/forums/general-q/361973-lifter-failed-wrecked-cam-were-they-correct-parts.html)
Scarron 07-23-2019 05:34 PM
As I was running gently back up the river last week at about 1200rpm I started to notice a tapping noise from the valve train on the port bank which sounded like a lifter to me when suddenly there was a loud squealing noise which went away after a few seconds them came back and went again, by now there was a distinctly noisy lifter. I managed to get the boat back to the pontoon and stopped it as soon as I could. The oil pressure had stayed good at 40psi all the time. Suspecting a lifter issue I stripped off the intake manifold to see one lifter missing the rivet holding the link bar on and its other half of the pair rotated and jamming again the block. The roller on the broken one is now square and the cam lobe is wrecked. so It's rebuild time..
https://cimg1.ibsrv.net/gimg/www.off...aaba6e5244.jpg
Missing link bar rivet and rotated lifters
https://cimg9.ibsrv.net/gimg/www.off...07581eeb74.jpg
Square roller
https://cimg0.ibsrv.net/gimg/www.off...e61a76846f.jpg
Gouged lobe
The engine is a Gen VI 502 block taken out to 540 with a callies crank and rods with 10.25:1 compression ratio and aluminium Dart Pro 1 355cc CNC heads.
It had a Lunati hydraulic roller cam 299/309 - 114 LSA and Comp Cams 15854-16 short travel lifters which came with a good recommendation.
Now I have looked to reorder the cam and lifters I see that this part number is recommended for the older series non OE hydraulic cam blocks. have I got the wrong lifters fitted and is that what caused the failure? the engine only had about 10 hours on it.
14 apache 07-23-2019 05:56 PM
The buttons are soft and the link bar wore through them. Look at the rest of the link bars I had that happen to another motor same thing. Those lifters are junk.
14 apache 07-23-2019 06:09 PM
Check the slop on the rest of the links and buttons you will se they are worn
BillK 07-23-2019 06:37 PM
Just curious, how much time on the engine ?
sonicss42 07-23-2019 07:30 PM
Says about 10hrs in original post.
BillK 07-23-2019 07:56 PM
Doh ! Missed it :(
BillK 07-23-2019 07:57 PM
How about a picture of the entire lifter valley with all of the lifters still in it ?
Scarron 07-24-2019 03:49 AM
Here you are; I haven't yet recovered the missing link bar rivet/button - it must have been loose in the lifter valley, as when I lifted the distributor out of the intake I felt there was a loose piece of metal sitting on it that fell back and disappeared before I could lift it out of the hole so it must be down in the sump. The engine is still in the boat so I need to get it towed to the marina and have it lifted out before I can take the motor out to strip it fully.
https://cimg3.ibsrv.net/gimg/www.off...5012e91fbd.jpg
The other link bars / pins don't look particularly worn but I'll get them out for a proper look. I'd have thought 10 hours wasn't a lot of time in which catastrophic wear could occur?
https://cimg4.ibsrv.net/gimg/www.off...f5a59ff59e.jpg
I am not clear which way the oiling in the lifter galleries flows, is it front to back? in which case this would be the last lifter on this bank to receive oil?
Trying to understand the root cause here, and I am not sure of the sequence of events, as I see it the problem could be; -
a] Perhaps the needle rollers seized due to a manufacturing defect or poor oiling. could this be because the incorrect lifters were fitted, would early style ones in a late block not receive correct oiling because the oilways come into the lifter bores at a different point?
b] Maybe the link bar button popped off allowing the lifter to rotate and the roller to skid/lock on the cam. What function do the link bars perform? are they to stop the lifters popping out of the bore with a high lift cam or are they designed to stop rotation [surely the standard OE lifter type without link bars could rotate in that case]
Are hydraulic lifters just troublesome, I had Morels in my last engine and they were inconsistent; sometimes noisy / didn't always pump up. So this time I went with these comp Cams short travel ones after reading recommendations. are they rubbish too as 14 Apache says.
Paul
BillK 07-24-2019 05:57 AM
Paul,
The link bars are to keep the lifters aligned with the camshaft.
The stock lifters use a different setup but still keep the lifters from rotating. The rollers have to stay aligned with the cam.
Might be the picture but the pushrods look like they are very close to the top of the lifter, almost touching ? The two failed lifters look like they have a lot of wear on the bodies. How do the others look ?
Just thinking out loud. I would certainly send the lifters back to Comp just to see what they say.
compedgemarine 07-24-2019 08:00 AM
from the look of it you have a heat problem on the two that failed. the bodies are black everywhere but the parts touching the lifter bore. none of the others look to be black at the top.
