-   -   Cam ID needed (https://www.offshoreonly.com/forums/general-q/362096-cam-id-needed.html)
F-2 Speedy 07-30-2019 07:09 AM
Cam ID needed
https://cimg8.ibsrv.net/gimg/www.off...c09809cacc.jpg
https://cimg8.ibsrv.net/gimg/www.off...43de52066c.jpg
16951 98F2A this is stamped on the core
its in a Mercury 500 EFI looks to be bone stock
F-2 Speedy 07-30-2019 02:56 PM
ttt.......I think its got a digit missing 169651 ?
SB 07-30-2019 03:16 PM
What is engraved and/or stamped on the end(s) of the cam ?
F-2 Speedy 07-30-2019 03:23 PM
maybe an X210 ?? I can read 98 for the yr
on the 165621 cam it has mhp-301 16-52-00 = 16th day 52nd week of 2000
SB 07-30-2019 05:42 PM
Crane 169651:
https://www.summitracing.com/parts/crn-169651/overview/
CRN-169651
Cam Style:Hydraulic roller tappet
Duration at 050 inch Lift:244 int./256 exh.
Advertised Duration:306 int./318 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.632 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.632 in.
Lobe Separation (degrees):114
SB 07-30-2019 05:47 PM
From my notes
https://cimg2.ibsrv.net/gimg/www.off...bbcb2e6992.jpg
SB 07-30-2019 05:58 PM
See:
https://www.offshoreonly.com/forums/...p-301-cam.html
Maybe answers this ?
And another good deciphering read:
https://www.offshoreonly.com/forums/...00efi-cam.html
Edit in: and below:
https://cimg6.ibsrv.net/gimg/www.off...125ca20c1b.jpg
F-2 Speedy 07-30-2019 06:18 PM
Originally Posted by SB (Post 4699476)
thanks for all the info, when I pull the other engine apart I hope it will solve the puzzle.
