Psa
Old 08-05-2019 | 10:14 PM
Tinkerer's Avatar
My point is that it wasn't a chunk.
It was vapor. The combustion gasses turned it into aluminum vapor.
Tinkerer is offline
Old 08-05-2019 | 10:55 PM
SABER28's Avatar
i get aluminum with its lower melting temp. but this was a cast iron head, right? looks like iron to me.
SABER28 is offline
Old 08-05-2019 | 11:33 PM
It is a cast head!
RBeyer is offline
Old 08-06-2019 | 09:08 PM
Rookie's Avatar
It's a common failure when a head gasket goes on an iron head. Take it to the machine shop and have them weld it with a high nickel rod. They have probably done 100 of them.
Rookie is offline
Old 08-07-2019 | 12:27 AM
Originally Posted by RBeyer
If the gasket failed hypothetically shouldn't it have been very obvious from that point that there was a problem. It's a Hawk 525 SC and it sounded perfect and actually made a bit more power than the other motor, I posted because I don't have all the answers.
I'd say it was making more rpms because it was running leaner than the other engine. Not sure exactly why it was leaning out, but I would look into possible causes.
Griff is offline
