2016 Merc 8.2 hard starting
Anyone have any idea why this engine takes a lot of cranking before it starts ? As an example, if engine is shut down and restarted a very short time later (a minute maybe) it will crank and crank with no fire. Shut off key, wait a short time and retry, it will start with some cranking. It just never seems to want to start like a normal fuel injected engine hot or cold - turn key for gas pump pressurize then crank, always starts but not as easy as other fellow boaters with EFI engines. Otherwise, engine runs finel !
2016 8.2 bravo 3x 380 hp batteries on #1, or 2 or both not much difference. 102 HRS new fuel filter and white screen, no improvement.(Merc products) |
What is the engine serial number?
When cranking do you see the tach showing at least 300 rpm? Does it start any faster if you give it a slight bit of throttle? |
S/N 2A503967
Next time I use the boat, I will check the starting rpm and try a bit of throttle. Thanks for the reply |
This a EC cat engine - the forums are not where you should look for info and I am saying this as experience from other boaters whom self inflict more damage in thousands with these exact engines.. There prob is not one person whom put a wrench on these cat engines up here nor ever scanned one so take that however but in a good way.
An example here of self inflicted damage --- a big back fire can blow a hole in the cats and if that happens its min of 5 to 6 k repair. My statements are to help but also want to ask why is a cert / EC boat dealer out of the question for the repair and see all issues at hand ?. Next your issue(s) is POSSIBLE ??? - there is an new harness adaptor that has solved the NO start 8.2 s. Also there is some recalls and PCM recal updates for the 8.2 s thru out the years. All this is thru the dealer whom has special scan tools called dealer / Merc G3 for a jist of the info |
Originally Posted by jjj
(Post 4703729)
Boat has been looked at for this problem at the one merc dealer on lake norman and they found nothing.
Also, the engine wire harness was replaced last summer after engine died on the water because it had a short... I would not do much of any fooling around on this engine because being a EC engine but I wanted to be a somewhat educate person when I go back to the dealer |
Gen 3 cool fuel could be the issue here.
What type of problem, engine runs fine once started, idle up to top rpm (close to 5000)
| All times are GMT -5. The time now is 04:26 AM. |
