Originally Posted by underpsi68
(Post 4706728)
I fixed it for you :circle:
ahhhhhhhhhh,,,i like it boost good one.. |
Big Heavy Vee's need Big Blocks. The 496 in stock form is almost bullet proof. Boost aside there is no replacement for displacement.
My 2002 29ft Sunsation will run 58 mph with a 377 in it, so i think you my have a problem. Prop maybe or just need plugs cap and rotor changed out.
My last boat had a 496ho and it was flawless, never missed a beat. That said, I've read quite a number of complaints about sensors and guardian mode with them so don't be too quick to change your 377 because of a couple of electronic gremlins. Top speed sounds a bit slow, tell the experts here your prop size and peak engine revs, it may just need a different prop to get things moving faster. First thing I'd do is make sure you're getting all you can out of the current setup before spending money on an engine change. My 2 cents, good luck and welcome to OSO. :) RR |
| All times are GMT -5. The time now is 04:34 PM. |
