Bravo sporadically getting after repairs... >
Old 09-17-2019 | 07:37 PM
Default Bravo sporadically getting after repairs...
Had gimble replaced at shop because I'm chasing a noise at idle. sometimes when pulling from F to N must pull twice. Also alignment was done. All was ok before repair and noticed once doing a on the water drive. It's going back to the shop but looking for ideas what happened. It's a good shop I have dealt with for years.
Thx
PA.WOODCHUCK is offline
Old 09-18-2019 | 12:49 AM
In English please???
Griff is offline
Old 09-18-2019 | 06:33 AM
English translation: Doesn't pull from forward to neutral at times after drive was off to replace gimbal bearing along with realignment.
Old 09-18-2019 | 07:00 AM
Bent Shift Cable .....
dunnitagain is offline
Old 09-18-2019 | 07:27 AM
Wonder if the top latch on the link bar is bound up so its not staying down, which would allow the cable to come loose
AllDodge is offline
Old 09-18-2019 | 08:08 AM
When going into forward is the cable pulled on at the drive, or pushed?
Old 09-18-2019 | 08:24 AM
Depends if you have a left or right handed prop
Unlimited jd is offline
Old 09-18-2019 | 08:29 AM
Right rotation
