I am lost!!! >
I am lost!!!
I am lost!!!
Old 09-18-2019 | 01:42 PM
  #41
F-2 Speedy's Avatar
Originally Posted by Raging Boater
i honestly don’t know- what will that tell me?
it will tell you if the smoke is from the crank case or seeping around the valve guide
F-2 Speedy is offline
Old 09-18-2019 | 01:44 PM
  #42
Originally Posted by flashgordon
is it smoke or steam???
maybe you have alot condensation in motor, when gets hot , pushing out breather.
but it looks more like smoke??
its white smoke that smells like burnt oil. Pulled plugs and changed oil no water
Raging Boater is offline
Old 09-18-2019 | 01:45 PM
  #43
ok, I will try that. Thank you
Old 09-18-2019 | 01:46 PM
  #44
Originally Posted by BillK
Not necessarily. If it is an oil ring it usually will not affect compression. A leakdown test would be next.
So did you build the engine or somebody else ?
Brother in laws father- he has built many and I trust everything was done correctly, but it’s me and this is my luck
Old 09-18-2019 | 01:48 PM
  #45
I don’t understand (I am not a mechanic by any means) if something was wrong wouldn’t there some indication? The motor starts and idles perfect, doesn’t skip, good oil pressure, no abnormal noises???
Old 09-18-2019 | 01:53 PM
  #46
F-2 Speedy's Avatar
From cold how long does it take to start smoking, just from an idle
Old 09-18-2019 | 01:54 PM
  #47
SB
Weird, your water bong looks like a boat engine.
SB is offline
Old 09-18-2019 | 02:04 PM
  #48
Knot 4 Me's Avatar
Definitely run it without the valve cover to see where it is emitting from.
Knot 4 Me is offline
Old 09-18-2019 | 02:10 PM
  #49
3-5 min
  #50
If you are going to run it without the valve covers get yourself a set of cheap stock stamped steel covers and cut the center out of them and install these. It will save you a ton of cleanup time and mess. Probably can get a set for a few bucks at the junk/pick-n-pull yard.
GLENAMY 242SS is offline
