575 SCI dumping fuel >
Old 09-23-2019 | 05:55 AM
Default 575 SCI dumping fuel
I have a 575 SCI single engine that started running extremely rich to the point that I couldn't get my boat on plane with a plum of black smoke behind the boat. Any suggestions sensor related ?
proscapes199 is offline
Old 09-23-2019 | 07:15 AM
bad map sensor would be my first guess
J. Hordubay is offline
Old 09-23-2019 | 04:23 PM
thanx for your response do you have or have had this engine with same problem.
Old 09-23-2019 | 04:47 PM
I would say to do some basic checks, fuel pressure, code scan, and check MAP data?
PA.WOODCHUCK is offline
Old 09-26-2019 | 01:06 PM
i know the injectors can be a issue as well
LTZCrew is offline
Old 09-26-2019 | 03:50 PM
dcb
Yes - odd ball injectors - no longer available. Check with BUP or Dave at MDG performance in Md. Eddie Young makes an injector kit to replace the obsolete TBIs.
dcb is offline
Old 09-26-2019 | 05:20 PM
i have eddies kit, super nice. also have stock injectors with low hours if that ends up being your issue
LTZCrew is offline
