measuring X ???? >
measuring X ????
measuring X ????
Old 11-05-2002 | 08:44 AM
dyno's Avatar
Charter Member #655
Default measuring X ????
OK someone must have asked before but it does'nt show up in a search....what is the proper way to measure my X demension?
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 11-05-2002 | 09:22 AM
Official OSO boat whore
The quickie method is to measure 9.25" below the gimble assembly to the bottom of the hull.
Cord is offline
Old 11-05-2002 | 09:29 AM
dyno's Avatar
Charter Member #655
Cord!!!!!Dude where you been?hows that cat running????and thanks for the Quickie......
dyno is offline
Old 11-05-2002 | 12:13 PM
Don't thank me yet, 'cause I got it wrong. What I meant to say, was...Measure the distance below the gimble to the bottom of the hull and ADD 9.25" to that number.
Can't really say how the cat is running. I got it out briefly twice, and had a couple of things that I wanted to correct. It's been so cold, that I gave up and I'm having it winterized. Would have been nice to just run it next year, but oh well.
Cord is offline
Old 11-05-2002 | 12:28 PM
dyno's Avatar
Charter Member #655
Good Luck !!!!post the results in the spring!!!
dyno is offline
Old 11-05-2002 | 04:01 PM
454hoho
Thumbs up right on
Just measured my template and Cords on the money
Old 11-05-2002 | 04:44 PM
Brad Perry
Is that measured from the bottom of the transom assembly? Are all transom assemblies the same on the bottom? (do all of them have that plastic mercathode box)
Old 11-05-2002 | 06:58 PM
No, you can take that mercathode box off. However, don't measure to that part. Put the tape tight to the transom, and it'll hit on the gimble near the gasket. Measure from that point down.
Cord is offline
Old 11-06-2002 | 11:09 PM
ragtop409's Avatar
So what is the standard mesurement (CORD style). What is considerd hi and what is low. Mine is 6" from the transom asemble to the bottom of the hull. Witch gives me 15.25? Charlie
ragtop409 is offline
Old 11-07-2002 | 11:59 AM
These numbers are for boats operating at 25mph and above. The x* number is the transom angle in degrees. You need to subtract 9.25" off the listed number for my quickie measurement to work.
16* 14 5/16"
15* 14 1/4"
14* 14 3/16"
13* 14 3/16"
12* 14 1/16"
11* 14"
10* 13 15/16"
For bravo boats that operate above 50mph the drive can be raised up to 3" above the listed number.
Blackhawk equipped boats start at a point 3" above the listed number and then can be raised 1 1/2" maximum.
Cord is offline
