-   -   Blackhawk drive shower (https://www.offshoreonly.com/forums/general-q/363828-blackhawk-drive-shower.html)
sandslot 11-10-2019 07:43 PM
I have not been able to locate a capable Blackhawk drive cooler. Suggestions? Maybe I have to pull fluid into the transom and a water/oil cooler?
tmmii 11-11-2019 07:22 PM
Simrek had some older showers that were for different steering systems. I believe marine marine was one that needed a special shower. The pick up ends were removable but then reattached through a sleeve that held the end and the main body of the shower together with set screws (I hope that makes some sense). If you found one of these I would think you could take it and bend and cut it to make it fit.
I will look, I may have a picture from one of my boats that had one like that.
BUP 11-12-2019 09:27 AM
You can install a water pick up on the transom and direct that water flow to the exact spots hitting the BHawk upper
SkiDoc 11-12-2019 07:44 PM
SkiDoc 11-12-2019 07:45 PM
I upgraded to Max marine top cap and shower
Donzi Z22 11-17-2019 12:20 PM
Craig Skilling , used a bravo 1 and bent it slightly.Look at the Donzi Marine Restoration on FB to see hie set up
sandslot 11-17-2019 12:33 PM
thank you!
sandslot 08-06-2024 08:43 PM
Hi - I am back at trying to identify a great drive cooler for my blackhawk drive. How did the max cooler above work for you? Can you point me to where I can get one of the ones in your picture above? Thanks
Sydwayz 08-07-2024 12:11 PM
https://maxmachineworx.com/
They are the only drive showers I would consider.
