Whippled 500EFI cam question
I did a search and couldn’t find an answer...I’m adding 3.3l whipples to my 100%stock 500EFIs this winter...bottom ends are fine going thru top ends... my question is, i have a pair of 651 cams, would they be too much cam for 500EFIs or should I look for 741s or should I just leave the stock cams in place since I’ll only be about 700-750hp with stock bottom end?
I'd upgrade to the 741,it will get you to the 750 mark.I've done them w/ the 8.1l cam thats a double swap and 240,248,,thats a really nice upgrade.
you have some one to retune it? |
What ECM are you planning on using
if i had the 651 cams i would use them,i have used them in a 502 before with good results.
(Post 4715177)
Smitty is your guy, we've done business for a few yrs now, he did my Whipple injectors last yr and have done a couple other sets also
Originally Posted by lucky cat
(Post 4715189)
Pretty sure it’s a MEFI3....I’m located in Michigan and I only know of a couple places here that Can tune the MEFI is Arcticfriends on the other side of State or Tyler Crockett over in Detroit... |
Originally Posted by articfriends
(Post 4715194)
I think we talked before, I have family with a cottege /house in Canadian lakes near Hardy so we could probably meet up over there and run it on the water. Even better though would be for you to drag a motor over and dyno it so we could make sure everything's good and get tune close before going in boat. I just Dynoed a 502 w whipple sidemount for john lambrestge / polebarn racing engines over your way , hes at hardy alot camping, Smitty
You can PM me. I just built a pair and made 760 @5400. I can give you some cam specs and grind info. Was on 3.3 Whipple 509 with 088 heads. Warning! do not send your boxes to Whipple for a flash, they lock them and only a few people can unlock them. Actually 2 come to mind. Good tuners out there and can give insight but I can help with an cam as well.
Originally Posted by mike tkach
(Post 4715188)
| All times are GMT -5. The time now is 09:26 AM. |
