How to remove these bolts
This penetrating oil creeps into a millionth of an inch. Works great. Google Deal Google Deal
For really nasty corroded stuff....I would simply weld a nut to the top of each fastener..then source new fasteners for reassembly.
The nut lets you put down the barbie allen socket bits and get some leverage without stripping...and if you are quick...the welding obviously applies heat.
I've used this method countless times on exhaust manifold studs/bolts broke off in cylinder heads....works well.
