-   -   Speedmaster heads For BBC marine? (https://www.offshoreonly.com/forums/general-q/364072-speedmaster-heads-bbc-marine.html)
snowrunner 12-02-2019 11:15 AM
Anyone tried Speedmaster heads on a 502 based motor? Look to be American made. Looks like they have an application that would work, 119 with 320 runners, “0.62 raised exhaust ports.
Would be used in fresh water.
SB 12-02-2019 11:23 AM
Speedmaster was Pro-Comp...if you are into that sort of stuff.
snowrunner 12-02-2019 12:06 PM
Thanks for the info was not aware. Have heard to stay away from pro-comp due to quality control.
TomZ 12-02-2019 12:57 PM
Unless you absolutely need aluminum, Engine Quests are a great cylinder head. I'd try that route.
sailtexas186548 12-02-2019 01:24 PM
I have two pair for sale at 50% of new if you want to give them a shot, run closed cooled for 10 hours never even went WOT. Mine came to me without spring locators on some “new” motors built by an unknown. Heads are ok I guess, I switched to EQ as mentioned above because I just don’t trust the speedmaster ones to stay together
snowrunner 12-02-2019 01:47 PM
I saw yours on Facebook marketplace. Made me think about them, but had similar reservations about them. My machinist warned me about procomp.
phughes69 12-02-2019 02:58 PM
Procomp had a bad reputation as being Chinese junk, but not anymore. They have really cleaned up their quality. I talked to Skip White performance about setting up a pair with inconal valves for marine use a few years ago. Full Force (Tim) had these heads on one of his engines a long time ago. I scoured the internet looking for the good, the bad and the ugly about these heads and only found that they were good heads if you bought them bare and put your own parts in them. I never found anyone who currently run them say bad things about them. A lot of people who trash them are giving out 2nd and 3rd hands info. Me personally Id go for the EQ heads. I got a deal on mine last year but I needed 2 pair
SB 12-02-2019 03:34 PM
Okay, I'll say some bad things without ever using them. :)
They have committed several acts of major fraud. How's that ?
Here's one:
Tue, 2006-08-08 20:00
MSD Ignition has obtained a Permanent Federal Injunction against Procomp Electronics, Inc.
and another:
DART MACHINERY, LTD. Case No. Plaintiff, Hon. v. COMPLAINT FOR PATENT INFRINGEMENT AND JURY PROCOMP ELECTRONICS, INC.and DEMAND PROCOMP MOTORSPORTS, INC. Defendants. _____________________________
sutphen 30 12-02-2019 04:04 PM
Here's one:
and another:
so your telling me they're pretty good stuff(except msd,since that crap fails for no good reason) because they made copies from quality castings.:D
I'll go sit in the corner now.
SB 12-02-2019 04:16 PM
I heard you like the corner. :) :wink:
This was a long time ago.
MSD does suck. I used to support them when things where good. BTW: Their oil filled canisters coils where made in America by same place most got theirs....Andover Coils in Indiana. Gov't put that oil on the hit list, and with OE vehicles going coil on plug and etc, the canister coil biz was gone in the states. Enter China. Ugggh. Believe it or not, lots of people believe it is the MSD coils that end up taking out the boxes. Also, a trick to help keep the boxes more reliable, is to ground the coil right to the engine when used as a capacitive system. ie: with a capacitive box. Keeps from having ground go to and thru box to battery and then back. :)
If the coil is used as inductive set up, you can't ground it this way.
ProComp got into this world by committing lots of fraud. I'll never support them.
I went with the Crane Box's before they folded. If in need of a new one, I'd go Daytona Sensors.
SB 12-02-2019 04:20 PM
Hey S30 - dare you to use their shaft rockers ! :popcorn: :)
F-2 Speedy 12-02-2019 04:36 PM
To the OP, raised exhaust ports could make an alignment issue for your tail pipes
sailtexas186548 12-02-2019 06:32 PM
HELL NO the SS stud ones are junk, just sold 2 sets for $20 lol
you couldn’t pay me to use their parts in a marine app. Budget race car... I might take a chance
snowrunner 12-02-2019 06:56 PM
Thx F2, was wondering about that. Likely going to stay with the old 088's.
mtnrider 12-02-2019 08:35 PM
I’m curious if you noticed any performance difference between the speed master heads and the eq heads
sailtexas186548 12-02-2019 08:36 PM
I can’t compare the two, didn’t run the sm heads hard and have very different cams/intake/exhaust
Rookie 12-02-2019 09:10 PM
so your telling me they're pretty good stuff(except msd,since that crap fails for no good reason) because they "SPLASHED" quality castings.:D
I fixed it for you. Now boaters should have no issues with the copies.
