525 EFI oil temperature >
Old 12-16-2019 | 07:44 AM
Default 525 EFI oil temperature
Just curious what y'all are seeing for oil temps ON A 525 EFI ?
New to me boat. With freshly rebuilt engines ..
I'm seeing roughly a 50 degree difference between engines ..
Not sure WHICH one to be concerned about .lol .
60 degree water after a Hard WOT run...
Boatally Insane is offline
Old 12-16-2019 | 12:54 PM
Once I’m up to operating temp it runs 175/180 coolant temp, 190-200 oil temp
your port oil tstat may be stuck open
Unlimited jd is offline
Old 12-16-2019 | 04:12 PM
LOL.. Dang.. was HOPING the 525's had SOME consistency..
My buddy sent me a pic of HIS dash from this past summer.. Seems HE runs about 135°
Old 12-16-2019 | 05:08 PM
That display shows 200* straight up and down. Looks closer to 180 to me
Old 12-16-2019 | 05:46 PM
DUH.. yep. You're right.. lol
THANKS !
Old 12-16-2019 | 06:02 PM
Mine is usually around 185. Whippled 509 525.
IGetWet is offline
Old 12-16-2019 | 08:17 PM
BUP
looks like 165 for one oil temp and 175 for the other oil temp. IMO that is too cold. Motor Oil flow better with heat and has to burn off combustion moisture at point in time so heat is needed..
BUP is offline
Old 12-17-2019 | 07:26 AM
Where are the temps being measured, before or after the cooler?
GLENAMY 242SS is offline
