Shark skin or dimples? >
Old 12-30-2019 | 11:29 AM
BUP
BUP is offline
Old 12-30-2019 | 11:50 AM
Here is what I came up with years ago.
-Blueprint the bottom.
-Sand the bottom 320 grit DA sander NOT orbital sanding direction from port to starboard. However Ive seen conflicting info on the direction and pattern.
-Strakes, hullsides and transom should be sharp edges. Make a tool and drag epoxy on the edges. Sand.
-Paint your lowers with HullKote Speed Polish, HullSpeed SuperGlide or KISS-COTE
-Paint your hull with HullKote Speed Polish, HullSpeed SuperGlide or KISS-COTE of course, these are polymers, you dont really paint them on, you rub them on.
-Have Wilson blueprint your lowers.
Keith Atlanta is offline
Old 12-30-2019 | 05:16 PM
Personally, I prefer dimples over shark skin.....
phragle is offline
Old 01-04-2020 | 02:16 PM
fastlane40's Avatar
So Osmosis maybe a good thing?
fastlane40 is offline
Old 01-04-2020 | 02:34 PM
Water has significantly more drag than air, it could however aerate causing a bubble barrier decreasing drag!
RBeyer is offline
Old 01-12-2020 | 01:01 AM
Add bubblers
old article
https://www.scientificamerican.com/a...cavity-system/
Crude Intentions is offline
Old 01-12-2020 | 01:29 AM
BUP
In my own mind I wrote a good story about some of this 6 years ago.
Yes I use to write in a marine Tech magazine that actually went out to 3 countries. My stories fell under the High Performance Corner in the magazine.
Here it is about the golf ball effect and air entrapment and blue printing and so forth. Read away its 3 pages long and I had to put my thinking cap on to write this story way back then in 2014.
https://www.emconsultinginc.com/Digi.../index.html#19
BUP is offline
