454 mag mpi combos with stock manifold and silent choice?
If you do put wrong cam under 1000 RPM may bring water in motor in slow zones!My 02 stock 454 mag stainless marine exhaust good luck!
This is helpful. I have to replace my cam due to the old one is too worn to reuse. Thinking Tyler Crockett has a cam and ecu program. I am not looking for top end but rather the pull and better sound. Sounds like stroking it and replacing the cam with the Tyler Crockett cam that is barely over stock should yield me the same power as a 502 and maybe a better lope.
Tyler upgraded our 454 MAG and it pumped power up to 461HP on dyno. Looked good and sounded nasty. Also was able to keep Captain’s Call option.
My 2 cents
