Helping 02`s live longer
Those CAT motors will always be trouble, just the environment they live in and not a great system design. There also using poppet valves to control the heat in the exhaust and they have had many problems
You need a scanner or Diacom software to find out anything that is happening. Or need a certified tech, because if the CAT gets the wrong mix it will be damaged and then its $1500 a side.
