Fuel Vent VS Fill Orientation
I'm currently in the process of ordering materials to replace my fuel fill and vent hoses. While researching the purchase online I came across a article that stated the vent thru hull fitting should be mounted above the fill. Another mentioned always 2' above the water line and it doesn't matter if it's above or below the fill. Currently and from the builder the vent is lower than the fill by about 1'.
I'm curious as to what the OSO community's inputs are on the orientation.
Thanks!
Thanks!
And keep the vent tube constantly higher than the vent fitting on the tank... if it swamps down lower, sloshing or overfilling the tank will hold a bit of fuel and block air flow - same principal as a plumbing trap...seems simple but have seen this problem come in on brand new boats (painfully slow filling)
FYI, combo fill vents/ the vent is on the side or btm of the filler where the fill nozzle goes in and on bigger boats the fuel fill on on the deck (some cruisers on the gunwale) and the vents are lower on the side of the hull. Shorter, sweeping runs (no pinch points) all for faster fuel fills and air to vent out of the tank...
I was curious to know if moving the vent to over the fill would alleviate this issue. I guess not considering the fill and vent positions on the tank would not change.
