Question about transom water pickup installation
I have a couple of questions about installing transom water pickups. I am installing them on my 1988 Cigarette 31 Bullet so the boat has a straight hull with no steps. I searched here on the board as well as other places online and it seems that some mount the pickups straight up and down while others mount them at an angle to match the angle of the bottom of the hull. I am sure both ways work but is one better than the other? I have the Hardin adjustable pickups so I will be able to fine tune them, but is there a recommended starting point on how much they should extend past the bottom of the transom? Thanks!
What are you using them for ? engine cooling, intercoolers ect.
(Post 4731380)
Originally Posted by Steve888
(Post 4731376)
I mounted mine straight down because i did not want them to
https://cimg7.ibsrv.net/gimg/www.off...3d9de542c7.jpg inter fear with the drain plug |
Mine are at an angle, so the pickups are perpendicular to the hull bottom. Flush with hull at the transom, angled down to 3/16” maybe 1/4 below at the rear. My boat is under 70mph so no water pressure issues
https://cimg3.ibsrv.net/gimg/www.off...fa154144f.jpeg |
Probably don’t want them extending past the bottom of the hull. Maybe level or up a little. The water curls up when it’s past the boat.
Originally Posted by tmmii
(Post 4731461)
Probably not that critical for a single stage pump. However, as the previous post indicated, as you increase your pump capacity you may need to increase the supply.
These homemade ones are feeding three stage pumps that serves oil coolers, heat exch, and intercoolers separate https://cimg9.ibsrv.net/gimg/www.off...fddd0b6ff.jpeg https://cimg4.ibsrv.net/gimg/www.off...c1195a56d.jpeg ly so they are oversized and flush in the leading edge with the trailing edge 3/16” low. |
| All times are GMT -5. The time now is 02:18 PM. |
