Oil temp high >
Oil temp high
Oil temp high
Old 04-12-2020 | 08:33 PM
It’s already been said, High AFR’s will make high EGT’s and cause high oil temps. That Hardin cooler keeps my 540 under 230* and I have closed cooling. Good luck and safe boating
ph1971 is offline
Old 04-12-2020 | 09:27 PM
Yeah just took a measurement on mine , the cooler is 3x16 and that’s from threads to threads so actually cooler tube is only 12 inches. Now that I’m typing this and reading it out loud that seems way to small, for what the motor is putting out. Even with all thermostats removed.
Deda22 is offline
Old 04-12-2020 | 10:03 PM
Originally Posted by scampbell90
502 mag. Didn’t upgrade oil cooler
That would be the issue. definitely needs a larger oil cooler.
Griff is offline
Old 04-13-2020 | 09:51 AM
articfriends's Avatar
3 things come to mind before you condemn the oil cooler/lines as being too small
1. Is gauge actually correct, you can shoot a infrared gun on dark areas on pan, cooler, fittings and see IF its close to correct, surface temps will read 20 to 40 less than actual
2. IF a high volume pump is used and a std bypass valve was put in block by accident, its possible to have it open and bypass hot, unflitered oil to your motor
3. as mentioned, if your running too much timing or lean afrs, alot of heat will be created and transferred to the oil
articfriends is offline
Old 04-13-2020 | 10:37 AM
Active Streak: 30 Days
Originally Posted by Rookie
You need minimum 3x18" CPH-550, CPH-700 if you want thermostat. Russ usually gives an OSO discount.
https://www.mrcool.us/coolers/hi-per...e-coolers.html
Are these coolers just more efficient than the stock Mercruiser stuff, or are these being used as a secondary cooler? I replaced one of the factory coolers a couple years ago, do to a crack over the Winter. Was nota Merc brand, but looked just like it. Does the same thing as others here, run it hard for a few miles and the oil temp heats up. New sea pump impellers do not make any difference.
BTW, my oil temp sensors are on the remote filter mount.
Last edited by Helmwurst; 04-13-2020 at 10:40 AM. Reason: Forgot to add last comment
Helmwurst is offline
Old 04-13-2020 | 11:25 AM
No to both
Your motor is producing more heat due to the increase in hp. The old cooler was designed to meet the minimum needs to meet the original motor build. Your new motor probably has a high volume oil pump (do verify and see if bypass valve has been plugged) and therefore it needs larger oil lines and cooler.
If you look thru my thread in previous post it will show what I went thru to get my heat down. You may not need to do all of what I did, and may need different things, but its one look at the issue and the process
AllDodge is offline
Old 04-13-2020 | 01:43 PM
Please excuse this question, but are you referring to the bypass that would be in the adapter or in the remote filter housing? I run a Wix 51649 filter without a bypass in the filter, if that changes things?
Deda22 is offline
Old 04-13-2020 | 02:24 PM
The valve is located on the block where the filter would attach or where the remote oil filter attaches. Mine was removed and plugged
https://www.offshoreonly.com/forums/...safe-oil-2.jpg
AllDodge is offline
Old 04-13-2020 | 02:45 PM
Talking
what engine(s) are you running? Overwhelming response are indicating oil cooler - I’m going to purchase just need to find correct one for me..
my motors are 547"s...
my oil coolers wont open till 210 temp,
posted num,ber for them,,,
flashgordon is offline
Old 04-13-2020 | 03:22 PM
seafordguy's Avatar
Before you buy anything shoot it with a temp gun.
seafordguy is offline
