Where to put Oil TEMP Sender
Thanks!! I'm also going to replace my thermostat when it goes back in...I feel like it might be sticking as I have too LOW of oil temps instead of the usual too high. I think maybe sender location and a possible stuck thermostat might have been my issues....I hope haha
I bought a used thermo/filter head here on OSO. I opted to replace the thermostat/spring and O-ring before install, good thing, the guy sold it to me WITHOUT A T-STAT AND SPRING, no warning from seller (thank you). Hardin Marine has the parts for that, just tell them you need the one with the shoulder, it is the same one they use in their oil systems.
Where is your temp reading from now?
Seems something wrong there, The oil should be warmer than the water. Your location is post cooler but still. Sure you have the correct temp sender in it? Oil should be in low 200's when running warmed up. I might buy another sender and replace, if the same wire for 2 like I was stating earlier.
Post a pic of location
Its the same location as his first pic...where the allen head is above the filter...I have all new autometer gauges and I have the sensor they recommend..The water temp takes the same sender and it works fine..swapped sensors with one another to make sure I didn't get a bum sender and had the same results...I plan on doing the thermostat and also warming up the sender with hot water or a lighter or something and make sure the gauge moves...I did ground out the sender wire and the gauge pegged as it should so I know the wire and gauge work as they should
Three things come to mind.
1) Could the thread sealer/tape you used on the sensor be causing a "no ground" condition to the block?
2) are you using any type of splitter with the temp sender? A tee or something? If so it will not work, the temp probe needs to be in flowing oil, not stagnant, that is OK for the pressure or warning but not for the temp sender.
3) When you relocate the sensor to the oil filter/t-stat housing if you did like I did and mounted it to the transom then you will need to add a ground wire from the filter block to the motor/battery.
I'll answer them with the numbers for ease lol
1. I thought of that first so when I did the ground check I pulled the wire and touched it to the body of the sender which tells me I and seeing ground through the thread sealer
2. I initially used a tee at that port and saw a thread on here saying the same thing as you just did so I moved oil pressure up to the back of the block right in front of the bell housing and installed the temp sender directly into the block with no tee.
3. Mine is actually mounted to the back of the port side head....I will still for sure check for ground there once its all up and running again.
I'm thinking that like alldodge said I may be running into a low flow/heat exchanger effect with the block or the thermostat is simply bad. Regardless I plan to try and remedy both before taking it out which by the way things look here in Michigan could be like October hahaha
Thanks for all the help guys!!
You know another thing to add here...I am currently putting a new motor in it and other than size everything will be the same in regards to sensor hook up and whatnot...that being said...the pan is currently off the motor waiting for install...is the "ideal" spot in the pan? I could easily weld a bung in the pan or replace the drain plug with an adapter while its off or would the spot in the filter housing work just as good?
