7/16 poly lock issue >
Old 04-14-2020 | 07:59 PM
Default 7/16 poly lock issue
Helping a friend swap to aluminum heads on his 500EFIs and had to order longer pushrods. Now the poly locs seem too short, it almost contacts the rocker body and most of the locking nut is hanging out. These are 1.125 long I believe. Do they make longer ones or can I use the stud girdle type. The roller tips are dead center on the valve tip not sure what I'm missing...Been a few years since i've dove in these things
kennyo is offline
Old 04-15-2020 | 01:26 AM
Lots of different sizes https://www.summitracing.com/search/...r%3A7-16-20-in
Is it possible that the rocker studs are too long?? That would cause the lock to stick out as well.
Griff is offline
Old 04-15-2020 | 10:36 PM
I’m assuming you ordered the right length push rods? The set screws are short so I wouldn’t want them to stick out any. I’d also say you might have to long of studs.
27formula is offline
Old 04-18-2020 | 02:52 PM
I think it's the other way. If the set screws are sticking out the and locks are way down into the rockers - the heads would need longer studs to get the locks raised.which will lower the set screws. Or do I have it bassackwards?
NHGuy is offline
Old 04-18-2020 | 03:59 PM
F-2 Speedy's Avatar
The OE locks on the 500,525 are shorter than the after markets ones, what heads are you installing ?
F-2 Speedy is offline
Old 04-18-2020 | 07:27 PM
Backwards. Sounds like he needs about a 0.2 shorter stud or 0.2 longer rocker nut. Which one depends on how much of the rocker nut threads are in contact with the stud threads.
Griff is offline
Old 04-20-2020 | 08:33 AM
How wide is the sweep pattern? What heads are they? You can be overly short on pushrods, and yet still have a centered pattern, it will just be very wide. I made this mistake years ago. I was told centered was good. Turned out my pushrods were waaay short. It worked, it ran. However, the next time I rebuilt the engines, I learned a thing or to. So I checked my old technique, against the mid lift method of setting them up. Sure enough, I was way off, and when checking valve lift with a dial indicator, I found I was losing a substantial amount of lift at the valve.
Theres many ways to do this, but without getting too deep, put your checking springs on with adjustable pushrod, and keep lengthening the rod watching the pattern get smaller. Eventually, you'll find it start moving towards the outside of the valve stem. This varies with different head brands, valve lengths, rocker brand, and so on. Or you can do it this way, like in the video.
MILD THUNDER is offline
Old 04-20-2020 | 02:16 PM
Never seen that video or used that method but GOOD info. Then again I don't keep my fingernails that manicured either. Lol...
getrdunn is offline
Old 04-21-2020 | 08:01 AM
Mild, that video was a really great and simple way of doing it! Thanks for posting!
Gimme Fuel is offline
