Holley HP EFI conversion >
Old 01-05-2021 | 11:23 AM
  #161
Originally Posted by ICDEDPPL
Crank trigger seemed like a paint in the a$$ to move pullies and install on my set up, more expensive too.
Dual sync way easier.
Unless you`re going over 7,000 rpm dual sync will work just fine.
did you cut the snout of harmonic balancer down?thats how I did it then its an easy install
sutphen 30 is online now
Old 01-05-2021 | 12:02 PM
  #162
I didn`t like that option, still more expensive and unnecessary imop.
ICDEDPPL is offline
Old 01-05-2021 | 04:00 PM
  #163
Panther's Avatar
Frank's Marine Service
Originally Posted by b18cls1
ive been running the hp with a dual sync dist and daytona sensors cdi box for a while now theres documentation out there for it, dosent matter if its a dominator a hp or terminator its all the same setup.
What you're writing is exactly what I'm talking about and they don't have documentation on it. There's no documentation out there on firing a single ignition coil NOT using a CD box and controlling the timing through the ECU.
What you're doing is running a single coil but the CD-1 is firing your ignition using the points output. The HP and Dominator cannot fire a stand-alone coil unless you use a CD ignition OR you have to run a Sniper ignition module.
Panther is offline
Old 01-05-2021 | 04:02 PM
  #164
Panther's Avatar
what crank trigger you run that clears the lower alt mount?
been thinking of swapping over to a crank trigger from my distributors
36-1 crank trigger
Panther is offline
Old 01-05-2021 | 04:09 PM
  #165
Panther's Avatar
Originally Posted by Rookie
Sweet setup!
I jumped the shark a month ago and bought dual sync and coil near plug setups. It wasn't the least expensive way to go, but I believe it was the right way to go.
Thanks! Carbureted it made 960hp and with this stetup it made 975hp out of the gate. I ran a smaller upper pulley to get the boost up and it made just under 1000 hp at 6psi. With a bigger blower it could have done a lot more.
Panther is offline
Old 01-05-2021 | 06:08 PM
  #166
just turn up that correction factor,,easy 1k hp.
Old 01-05-2021 | 06:57 PM
  #167
Rookie's Avatar
You don`t need an additional box to run coils.
HP and Dual sync is all thats needed.(and a couple subharnesses)
DId you figure this out how to fire a single coil without the box? This is the answer to the question I had a few pages ago.
I'm going to need some advice on coils and ignition boxes. (do I still need a box if I use the HP computer?)
Even if I am not running coil over? Just single coil using the distributor to supply spark.
Rookie is offline
Old 01-05-2021 | 07:20 PM
  #168
I’m sure you figured it out but it’s just a simple Bosch inductive igniter.
b18cls1 is offline
Old 01-06-2021 | 08:08 AM
  #169
Panther's Avatar
That's correct, there isn't documentation out there from Holley on it. They just assume that you're going to either use a CD Box, GM distributor or coil on plug. They have documentation for the Sniper system for a single coil with no box but not the HP or Dominator. I figured it out on my own a few weeks ago.
https://www.holley.com/products/fuel.../parts/556-150
Panther is offline
Old 01-06-2021 | 08:10 AM
  #170
Panther's Avatar
Yep, this is the answer; https://www.holley.com/products/fuel.../parts/556-150
Panther is offline
