525SC Catastrophic test run. Seeking rebuild advice. >
Old 04-27-2020, 07:46 PM
Originally Posted by Griff
I'd be more curious to see what the pistons and head gaskets and spark plugs looked like.
The biggest issue with salt and the 525SC is the water ports on the intake manifold where they mate with the heads.
My engine was a 1996 with about 340 hrs on it and I'd had for a 140hrs in fresh water only HELP!!! Need Merc 525SC Intake
Thanks for the link. How did the alluminum welds hold up? Why wouldn't the Weiand intake work?
If I could run the motor raw and just change the intake every few years it would almost be worth it. The whole heat exchanger thing is a pain.
SCARAB.23.SCS is offline
Old 04-27-2020, 07:47 PM
Originally Posted by wayne272
I have a cigarette bullet that was running 454mags, 8.8:1 compression with 990 heads. I installed a pair of weiand 177's, swapped to a blower grind flat tappet cam, and pro magnum roller rockers and a V6 ignition module on 93 octane. Dynoed at 575hp and boat picked up 10-15 mph.
Nice setup. Since I have to buy new pistons anyways I figure I might as well bump up compression to 8.5:1. I wonder how much HP I would gain just by the compression change. We have up to 94 octane fuel at one gas station in town!
Old 04-28-2020, 12:44 AM
Received 1,826 Likes on 911 Posts
I sold the boat with when it had about 475 hrs and never had any issues with the welds. The intake was never pulled off again by me or the next owner who maybe put another 50 hrs on it before replacing it with bigger power. I believe when I was looking way back when I posted that thread the Weiand intake was going to have issues with the stock Tstat housing hitting the blower snout.
Griff is offline
Old 04-29-2020, 09:29 AM
blue thunder's Avatar
I believe my motor has a 160 degree thermostat, when I was out cruising for the 15 minutes my motor lasted it was bouncing between 160-180. Maybe put in a 140 t stat then?
Also, ive read on a few forums that these motors should be at 35 degrees timing at full advance. Any performance loss running 30? ( I would rather be reliable anyways )
Do you have an opinion on bumping compression to 8.5:1 since I am buying pistons anyways?
Thx
I run 177s (525sc take offs w/ dominators) with 741 cams and closed cooling. I run approx 9.3:1 compression with aluminum heads. I run a v-6 module with 31* timing all in. With closed cooling I run no tstats and runs 150* cruise and will go 180f wot. 6lbs boost or just under and wot rpm around 5500rpm. I would definitely bump compression to 8.5:1 if you go with the 731 cam. You might want to locate a dynamic compression calculator and play with that to see how your combo stacks up with the cam you choose. 8.5:1 dcr is the max and lower is safer. Note that static is different than dynamic compression and dynamic compression is what you really want to nail down. Also since its apart put some effort towards making sure your quench is in the .040" range. No lower but not more than about .050" either.
BT
blue thunder is offline
Old 05-01-2020, 10:18 PM
BT
Thanks for the info!!
What size heat exchanger do you have? Mine is 4" diameter and about 24" long. I guess the point of running no T-stat over a 140 is increased flow?
Just heard back from the machine shop today and the block is getting bored 0.30 over and I will need new pistons, any recommendations on brand?
Also, if I end up buying the 731 cam, will the stock 525SC valve springs be good enough for the cam or will I need springs along with hyd lifters? I wasn't going to touch the cam but people seem to love the 731...
Thanks again for info
Old 05-01-2020, 10:21 PM
Rookie's Avatar
Received 1,212 Likes on 583 Posts
New springs and lifters are needed. Flat tappet to Hydraulic roller.
Rookie is offline
Old 05-02-2020, 01:29 AM
You should be replacing valve springs no matter if you keep your stock cam or go to 731.
I'd use these JE pistons 139477
Will give you an 8.2:1 Comp Ratio. https://www.jepistons.com/applicatio...-open-chamber/
Griff is offline
Old 05-02-2020, 11:49 AM
Thank you for the part number, I will use them. The reason I was going to leave the springs was when I bought the motor it had a fresh top end just done. Springs and crane roller rockers.
Old 05-02-2020, 12:27 PM
If it had new springs and you stay with the stock cam then have your builder double check the spring pressures or For the $83 for new ones, just replace.
These are the stock springs https://www.summitracing.com/search/...yword=99839-16
Griff is offline
Old 05-02-2020, 12:30 PM
If it had new springs and you stay with the stock cam then have your builder double check the spring pressures.
What springs would I need for the 731?
I keep hearing that it wakes these things up!
I just bought a 28P bravo 1 prop so I need to spin that thing
