1998 502 update options. What would you do?
So... are you guys saying don't bother doing any modifications at all? Or just wait until next year?
Pretty sure I know the answer, but want to verify.
Thanks for the suggestions, I really do appreciate it.
Dont do ANYTHING to the motor this year or next year or the next except have the injectors serviced. Ditch the captains call . Make sure the there are exhaust flappers on the outside of the exhaust and also flappers on the inside of the exhaust. The flappers are VERY IMPORTANT. If you lift up the external flappers and shine a light through the thru hull exhaust you should see a metal or rubber flapper. Probably rubber. Its a butterfly type. If you just see a metal rod in there it has burned out. MUST BE REPLACED.
Chris
Chris
Chris
A 502 mag/mpi can go 700+ hours without major work. I would do the injectors as recommended above. I believe the MPI had flat tappet cam for a couple years which you would want to make sure you run the proper oil.
Thanks guys.
Not what I wanted to hear, but prob what I needed to hear.
Just talked to BUP and will be moving forward with the injector service.
Now I need to get a list of all the gaskets/O rings needed to access the injectors.
***Hint:*** anyone doing injector service might want to put together an O ring/gasket set for injector installation.
I reused the intake seals after clean and flow without issue. My injectors came back with new O rings for rail installed and new basket screens. Get some glycerin (KY jelly) to use to reinstall injectors back into the rail. The complete seal kit is 25-805511A1 and BAM sells for 18.09 each
https://www.mercruiserparts.com/805511a1-sealing-kit
