UJoint Bellows Bravo 3 >
Old 04-29-2020 | 07:18 AM
Default UJoint Bellows Bravo 3
Is it possible to change the UJoint bellows on a 1997 Bravo 3 transom assem without removing the bell (with 6 bolts) using the hing pin tool? Did it once on an old pre Alpha without removing anything but the drive. It was a pain but doable. Thks
Pismo10 is offline
Old 04-29-2020 | 08:21 AM
Yes, if you pull the exhaust bellows out of the way you can pull the u-joint bellows out the bottom. I did one yesterday.
Unlimited jd is offline
Old 04-29-2020 | 08:47 AM
So pull exhasut one first then go from there.
Pismo10 is offline
Old 04-30-2020 | 10:52 PM
I've always just pulled the bell. Are the pins seized or stripped out?
smashm is offline
Old 05-01-2020 | 07:12 AM
seafordguy's Avatar
Assuming they are the same as B1's I can say I've changed them without even removing the hinge pins, but that required a lot of cussing and fighting. Pin removal is easier.
seafordguy is offline
