-   -   Lighting headers to dry tail pipes (https://www.offshoreonly.com/forums/general-q/366140-lighting-headers-dry-tail-pipes.html)
Onesickflhxs 05-05-2020 01:24 PM
Believe since was hacked up so bad wouldn't fully seal. Heard alot of lightning will get reversion https://cimg9.ibsrv.net/gimg/www.off...de4c1e4888.jpg
Onesickflhxs 05-05-2020 01:25 PM
Finally 10 posts. I prefer the water to be dumped closer to the pipes if not thru the hull.
https://cimg5.ibsrv.net/gimg/www.off...33a9d99210.jpg
https://cimg4.ibsrv.net/gimg/www.off...79f96d6ca.jpeg
LakeHuronPower 05-05-2020 01:37 PM
You could by their jacketed thru-hull tail extension (541410) they don't look like they weld on like the collector extensions. Other than that you could make any custom setup you wanted but need to have the pipe cooled.
Onesickflhxs 05-05-2020 02:01 PM
Those are what I wanted but he wont sell them..and honestly the dude was not good to deal with. Looking at just making a set for now
ThisIsLivin 05-06-2020 10:06 AM
What is the difference between the 2 diameters? Permatex makes a high temp silicone I use on header gaskets that will work to seal the inner pipe to the outer. Otherwise cut the outer diameter back and tig weld the inner tubes together.
