Thoughts on using 2 year old gas
Drain as much as you can - I also have a 7.4 MPI - the last thing you want is something squirrely going on with the injectors. I'm sure there is a lawn service that would gladly take this off your hands - once you get to about 10 gallons I would fill it up with premium - a couple of cans of Seafoam and run it as much as you can. I really think you should be pretty good. For sure you want to keep an eye out for a set impeller - that might need to be changed. All the best
3pointstar
3pointstar
Remember heat is gasoline's biggest enemy. If it sat in the Fla heat for 2 yrs then get rid of it for sure but if it sat up north for 2 yrs in inside storage I wouldnt worry too much about it.
Drain it from the boat for sure. Pour abt 4 or 5 gallons in your car/truck right before you fill it up. If the octane has dropped, your cars computer will see the pinging and retard timing automatically. After you run thru all of it, replace the car's fuel filter.
