SSM 5 Cavitation plates >
Old 05-11-2020 | 10:40 AM
Default SSM 5 Cavitation plates
I did a search, couldn't find the thread. I remember someone adding cavitation plates to SSM 5 drives?
Anyone here have experience with this? Thinking it may help me get on plane quicker?
frickstyle is offline
Old 05-11-2020 | 04:02 PM
I have my props in your neck of the woods , adding cup to get on plane easier, I`ll let you know how it turns out
Propeller Service & Sales | Sante Marine Propellor | Cleveland OH
Cav plate your have to machine something to sandwich between lower and upper. Doesnt seem easy but if you get it done i`m in for a set
ICDEDPPL is offline
Old 05-11-2020 | 05:20 PM
Post 101 an 108
Great lakes flat decks check in!
ICDEDPPL is offline
Old 05-12-2020 | 06:55 AM
thanks Dan. Yep, would have to go in with the spacer. Wondering if I can drill into my spacers to make it happen, otherwise you are basically making a spacer with a wing on the back of it. That's gonna be some work; o-ring grooves, pins, etc.
Also, I thought you already had that done? I had BBlades do one set, didn't really make any difference... Encouraged to hear what you end up with. 4 or 5 blade?
Old 05-12-2020 | 08:30 AM
rv
I have set of Merc 5 blades that should solve your problem.
Don't drill #5 case for cav plate they are in short supply and from what I heard they don't help.
Rick 847-502-2399
rv is offline
Old 12-01-2020 | 07:50 AM
bob
Charter Member #40
Anyone ever try cutting back some of the plate at rear of housing to improve flow somewhat to upper portion of prop? Looks like on a straight bottom Cig 38 I am loosing 7.3 degrees of negative trim due to Merc transom assy. Anyone ever try modifying drive to allow for more negative trim? Adding minimum .100" cup to 18" dia four blades definetly helps but still could use some help on over 30 pitch wheels. I am leaning on removing maybe 3/4" of rear portion of plate. May be of some help.
bob is offline
Old 12-01-2020 | 08:21 AM
Did you ever end up putting on a cavitation plate or are you still looking for one?
Andrew56 is offline
