K plane electronic indicating on simrad orVV
Looking for options on how to install electronic indicating on my Kplanes to my vessel view or simrad. I do have a nema 2000 network already with engine data already on the simrad.
hmmmm,,,i dont know about electronic indicator..sorry
i have all mechanical keikhaefer indicators. good luck |
Later style K-planes have a provision for adding Mercury senders, so you would just need the sender and hardware. Since you already have VesselView you can use the Mercury trim harness that connects both tabs to one of your engines. That will let broadcast trim tab position to VesselView and / or Simrad.
GF? |
Originally Posted by Got Freedom?
(Post 4738868)
GF? https://cimg8.ibsrv.net/gimg/www.off...71fbdbcaa1.jpg |
Mercury has a harness and trim tab interface module that plugs into the smartcraft junction box, and the. The Vv needs to be setup as 4 engine from what I understand.
Originally Posted by Unlimited jd
(Post 4738967)
Thanks. ill look into that. Also maybe this mayfair box will work. It converts analog to nema2000. Could use the merc sensors still I'm sure since its just a resistor. https://www.hardin-marine.com/p-1003...ndicators.aspx |
I know this is an old thread, but what did you find out that would work?
Depending on the motor and age you may need the trim tab interface unlimited JD mentioned above. Other wise you wire the digital senders directly to a motor, connects to a square 4-wire plug, then set up in the VV or simrad is a little screwy. Im
sure someone at merc or maybe Livorsi can explain the process |
| All times are GMT -5. The time now is 05:26 PM. |
