Hp500 Circulating water pump >
Old 05-15-2020 | 05:04 PM
Default Hp500 Circulating water pump
Hi
is there a replacemen circulating water pump that can fit on my hp500 without buying it at mercury dealership ? I know that gmc put some 8.1 and 7.4 in there truck few years ago.
Perf langlais is offline
Old 05-16-2020 | 12:29 AM
You could go with a Sierra brand one, but I would go with Merc.
I would not use an automotive recirc pump. The internals on auto ones are designed knowing it will have AF and they don't have SS internals.
Griff is offline
Old 05-18-2020 | 09:00 AM
Using a marine pump is really critical if you don't have closed cooling. The seals are different and the automotive pumps need AF to lubricate them. I you have seawater cooling, you better make sure you bilge pump is working, because you will need it. I've burned out a couple of water pumps on cars running straight water before.
ThisIsLivin is offline
Old 05-18-2020 | 09:32 AM
F-2 Speedy's Avatar
Ive used these before with no issues,
GLM Products Inc - Water Pumps
F-2 Speedy is online now
